Unhide items when using Select command
Hi all.
Is there any way to "unhide" items if using Select with a filter causes those items to match the filter?
E.g. If I use SELECT DESELECTNOMATCH HIDEUNSEL FILTER=myfilter, any item that was previously hidden won't be shown. The current workaround is to use something like SELECT NOPATTERN SHOWHIDDEN beforehand, but that causes some issues too, like:
  • Visible flickering of items.
  • Even if the filter does not give any result, all items will be displayed briefly.
Maybe a new argument like UNHIDE would come in handy? I'm referring to something similar to SELECT FROMSCRIPT=unhide, but in this case, I don't have the items set beforehand.
Thanks.
In the next update, you'll be able to combine SHOWHIDDEN with HIDEUNSEL and HIDESEL.
