Is there a quick way to open a single list (window) exclusively on the USB port without the usual displays but keeping the standard columns?
Saving/loading a layout is probably the easiest way.
(Depending on what you mean by "without the usual displays").
You mean opening a lister is removing the usual displays, i.e. buttons and icons.... in order to save all of this as "empty usb lister" I agree with you, but is there not a way or a command that can do all of this??
From the main menus, Settings > Lister Layouts
