I'm having a problem with tabs that are set to prevent loading on startup. I want this for network locations, but the issue also happens for me if I set my local drives to that setting. After opening a lister, those tabs are not loaded, as expected. Upon loading them by clicking the provided link or by pressing F5, however, their folder format, as indicated by hovering over the lock icon (it is unlocked), comes from "unknown." Folder formats that ought to be applied are therefore not applied: for example, I have a wildcard path set to make one of my folders show in thumbnail mode. Because the folder format system is not being applied, thumbnail mode is not used until I manually reset the tab to the folder default. In the Launching Opus preferences, "Ignore folder format of Default Lister" is checked.
