Settings where initially exported from a x64 Windows10 installation and imported on a arm64 Windows11 installation. That gave me the current color problem. As said reverting to the Default Dark or Light setting does not solve the problem.
Does anybody have a clue?
Any help is appreciated!
It’s an issue with ARM machines. With some dropdowns it affects light mode as well, as the mechanism used to paint the dropdown contents doesn’t work with Microsoft’s current x64 emulation.
Any update on the native ARM build you mentioned in november?
I've been using DOPUS since the Amiga days and am a bit disappointed with the performance on my Samsung ARM laptop!
