Hi there! o)
In the button editor, the dropdown-submenus for a given script command show all uppercased entries while they're lowercase in the script commands template. The menus used to show lowercased sub-items for built-in commands since ever. Just a minor glitch, but in case you feel like equalizing things.. o)
If you just use the casing as it is in the commands template, it would maybe allow for some easy to read descriptions for placehoders.
What I try to say is, having these sub-menu entries forced to lowercase is probably not necessary, just no forced uppercasing I'd think.
Cya, tbone
Script command:
Internal command:
