When you do these steps:
Click floating toolbar's Menu icon (threebutton or normal menu) URL shortcut, Dopus will open file explorer window (Dopus) in the background
Is there a way to disable this?
URL shortcuts don't usually open Opus windows. What does the shortcut point to? What's the command that the button is running?
Try removing the Go and quotes and just leave the URL on its own.
Worked like a charm, thank you Leo.
Could it be fixed so that when you drag & drop bookmark from browser, there wouldn't be the "GO" in front of URL?
That makes sense, yes. That or we'll make the Go command do the same thing so existing buttons made that way work better without needing to change them.
Decided against changing the existing behavior of the Go command, in case it broke something.
But now when dropping URLs from a browser to a toolbar, Opus will create the proper command and also extract the name the browser suggested for the button's label.
Okay, that's not a big issue to manually remove the GO from shortcuts, better than braking something.
Would it be possible if Dopus could fetch the websites favicon somehow?
That is the biggest & most time consuming task when adding URLs to Dopus toolbar.
