USB export issue
After exporting to USB (complete config) some files/folders won't be copied with latest DO.
I have some tools in usercommands\tools-folder that won't be copied.
BTW a question: What is the relative path to use them in USB-Version? I tried misc aliases without success.
usercommands\tools isn't a standard config folder (AFAIK; usercommands is but usercommands\tools isn't) so I'm not surprised it isn't exported. (Was it exported in the past or something?)
You could try using a folder called "scripts". I think I read that whatever is in there will be included in a config backup. Haven't tried it myself and it's not a documented feature but it might work.
In what context?
I use some external commands (truecrypt, syncback, autoruns, etc.) which are stored in usermannds\tools.
To run from USB I need correct pathvariable to start. I don't get it :cry:
Found, /dopusdata! Unfortunately not working with icons.
