I wondered whether I can add an entry to the context menu to copy/move files easily by having a nested dropdown of destination folders. Turned out that's quite easy - amazing how DOpus is btw
- see the first "Copy to Personal" item in the screenshot.
However, I often have the need to further work with the moved file, e.g. rename it, resize it if it's an image etc.
Thus:
- Is it possible to use
Go X:/ FOLDERCONTENT=movein combination withNEWTAB, so that in addition to the move-operation I get another tab opened with the destination where the file is moved to? I tried but it doesn't work, the file is moved, but no new tab is opened. - For more powerful actions, I wondered whether there's an option to get the result of
Go X:/ FOLDERCONTENTand store it to a variable for further processing, without opening a new tab or doing the move? As in this pseudo-code:
selected_dest = Go X:/ FOLDERCONTENT # returns the user-selected path
Go selected_dest NEWTAB
COPY selected-file-in-source TO selected_dest
do-some-more-with-the-copied-file
