Using custom quick filter settings
I use following quick filter:
FIND IN H: K: L: M: P: R: NAME {dlgstring|Suchbegriff eingeben} QUIET SHOWRESULTS=tab
Is it possible to include some enhanced filter (saved filter), that is skipping several directories in those drives, like sandboxes,
database files, or extensive portable app dirs (e.g. Open Office is notorious for having about 1.3 zillon files, that will delay the search needlessly)?
So, for example, i want to search L:, but exclude L:\Sandbox, etc.
So i´d like to keep the quick & simple input field, but have a bunch of places filtered out for speed enhancement. Maybe
the code has to be changed completely, since i don´t believe it can run those drives & the subfolder rules at the same time
(except for two passes maybe, what would eat up the saved time).
I don't think you can at the moment.
The Find command lets you specify a name pattern to search for or a pre-defined filter to use, but not both.
There's something else that might work but I haven't really tried it yet. I'll send you a separate message.
