Using "DOpus.SetClip" to send UTF8 text to the clipboard will be garbl
Run in CLI
'Copy Content
FileName = "D:\Temp\test.pas"
Dim STools, TextBlob
Set STools = DOpus.Create.StringTools
With DOpus.FSUtil.OpenFile(FileName)
	Set TextBlob = .Read()
	.Close
End With
FileContent = STools.Decode(TextBlob, "UTF-8")
DOpus.output FileContent 'The log window output is normal
DOpus.SetClip FileContent
DOpus.output "========"
DOpus.output DOpus.GetClip("text") ' There is garbled code.
Select "Paste" in the background menu of the file list, the text file will be garbled
Adjusting "clipbord_text_encoding = utf8nobom" is also invalid
test.zip (5.0 KB)
It seems OK here:
I am using the simplified Chinese version of windos 10 (2004 19041.450). Is it related to the default encoding of the operating system?
I think it is still the problem of dopus.setclip method
Use the clipboard function provided by vbsedit
剪贴板图片 (3)
I switched Windows to that and was able to reproduce the problem.
A fix will be in the next beta.
Thanks for the report and the extra details!
