Using filters
How do I get a lister to show for a particular folder, only files that match certain files extensions - e.g. *.txt, *.bmp, *.pdf or something.
In folder options, filters, I can set *.zip to get only zip files shown but if I enter multiple file extensions, it doesn't work.
Also, once the filter is working, is it possible to have a button that allows me to show all files, then switch back to showing just the filtered files - regardless of which folder I'm looking at.
Also, is it possible to set up an include or exclude filter that I can apply to any folder without going through tools -> folder options and creating a new filter all the time.
Why is folder options on the tools menu - it's not a tool?
Why do "filters" and"styles" not appear in the help index? To find info on filters I have to search on "filters", which finds a whole heap of topics, the first of which tells me "Directory Opus has an exclusive file filter system" without telling me how to get to it.
What's "exclusive" about the opus filter system? In my opinion the help should provide information, not keep on telling me how great the product is.
Also, how do I find information on what the attributes R,H,A,S,E,C in the filters dialog box stand for?
TIA
For multiple extensions, use *(.ext1|.ext2)
I'm not absolutely certain, but I expect the attributes are:
[ul]Read Only
Hidden
Archive
System
Encrypted
Compressed[/ul]
