Before I did a recent reinstall of Opus 9. I thought I could do the following.
Put the cursor focus on a text file, and then click on the NoteTab icon I put on my toolbar to run NoteTab Pro. The file would then open in NoteTab Pro.
I guess a setting somewhere must have changed. as when I do that now, NoteTab Pro opens, but to a blank screen - the txt file does not open. If I do double click the file in question, it does open in NoteTab Pro.
But sometimes, I want to open a file to edit, and the file might be something such as a *.bat file. And double clicking on that would run the bat file, which I do not want.
What is the path to the setting to click on my NoteTab Pro icon, and have it open the selected text file?
Just add {f} after the full path to the NoteTab executable.
C:\Program Files\Notetab Pro 5\NotePro.exe {f}
I have my NoteTab button set up as a 3 button button. A left mouse click opens NoteTab Pro without loading any files while a right or middle mouse click opens (or switches to) NoteTab loading the selected files.
AB it's been years since I set up my NoteTab button in Opus but checking the code now it appears that either {f} or {F} will work nicely. With either one NoteTab opens each selected file in a new tab on my machine.
