I have two separate copies of a complex directory with over 100 sub-folders and 7,500+ files.
The copies should be - but are not - identical. I need to identify the differences in these directory trees,
so that they end up faithful copies of each other. The differences are probably less that 5%, but I cannot afford to lose
5% of the files.
Any suggestions how I can do this with Opus?
thanks
[ul][li]Synchronize panel[/li]
[li](Copying Updated Files may also be of interest.)[/li][/ul]
The built-in Sync panel may be all you need. But, if not, you can use Opus to launch dedicated diff/merge tools which are even more powerful and integrate well using either of these scripts:
