V12-update issues (solutions)
I noticed that some things won't be updated automatically e.g. from v11 to v12. Maybe it's an issue with my config, but for others having same issues, here are some solutions:
Missing entries in filetype-contextmenu (e.g "set label", "set status",...):
  1. Get a default DO-setup (e.g. backup your config, exit DO, delete "C:\Users<you>\Appdata\Roaming\GP Software" and run DO again - a fresh config will be created).
  2. Copy "/dopusdata\filetypes\AllFilesystemObjects.oxr" from fresh config.
  3. Restore config, copy above file back und restart DO.
Missing default status icons in USB-version:
  1. Go to "config > favorites > labels"
  2. Go to search and enter "/dopusdata\dopus.exe" as path.
  3. Select the desired icon.
