Variable for filename without extension?
Heyo!
I did a button to create a file, which get's the name of the selected file as filename, and fills in the name in the txt.
The button runs a MS-DOS Batch function:
echo DirectShowSource("{file}") > "{sourcepath}\{file}.avs"
With this code, when I mark f.e. hello.wmv, a text file named hello.wmv.avs is created (the part after ">"). But I want to have a hello.avs-file.
So I would need a {file} parameter without file extension.
Is there one? Or do you know how I could realise this script without getting .ext into the created filename?
Use {file|noext}
(Or, better, {file$|noext} so that the button won't do anything if you accidentally run it when nothing is selected.)
Works, thanks! :slight_smile:
