Great program and I have purchased Dopus 12 (and in the past Dopus 11).
The only complaint I have is that the viewer pane is slow when viewing text files.
Moving the mouse over the viewer pane makes the mouse flicker between the normal mouse pointer and the selection caret. This constant flickering results in the mouse movement being slow.
Can you somehow fix this? Maybe only switch to the selection caret after the mouse has been stationary for say 500ms?
I use the viewer pane all the time for text files and this "bug" is rather annoying.
