12.18.4 Image viewer
Right control cursor is normal.
What kind of file are you viewing?
I can't tell what the screenshot shows. It looks like a white line on a black background?
PNG file, this is a merge of two screenshots.
The cursor's range to the left is too large, beyond the left edge of the screen.
I see what you mean. (I've edited the thread subject to make it more obvious.)
The cursor had its hotspot in the wrong place (which didn't affect much as it's never used to point to anything).
We've adjusted it for the next update.
Thanks Leo, it has no impact on any features, it is just a very small detail.
