Hi,
In both DO 12 and now 13, for WebP files, the Metadata Pane doesn't display info like the pixel dimensions.
More precisely, when I have a WebP file selected the only info I see in the Metadata Pane is for Extended Properties and Standard Properties. There are no sections showing Non-editable Properties (which has the pixel dimensions), Document Properties and Picture Properties like I get for JPEG files.
When I hover over a WebP file I get a popup giving the files pixel dimensions and a thumbnail of the image. Webp files are also successfully shown in the Viewer Pane.
Can you offer any help as to why I don't see metadata like pixel dimensions for WebP files in the Metadata Pane?
Thanks
