If I have my screen split vertically and I key into the filter box "keyithere" then go back to edit it using the cursor keys I cannot get to the beginning 2 letters but there's also odd movement of the cursor or maybe better said it get's stopped from going left when it hits the left side of the box and the cusor disappears. If DO goes to the background and selected to come bac to the foreground the beginning of the keyed string will appear.
Being able to see the whole screen would be good here.
In vertical dual mode adjust window width or dual divider until it matches the size of filter bar edit box that's shown in the video.
Just to update this, we have confirmed it, but don't have a fix yet. It seems to be a bug in the Windows edit control where it ignores the margins set on it if it's too narrow to display the full text.
