12.18.3
All back to the original black.
12.18.3
There's no detail here. What is this about?
I set a lot of labels, red, orange. Mark all software and files. After installing 12.18.3, they all returned to black. I didn't notice this after installing yesterday. I checked the settings of the tag and nothing changed.
It is probably the problem of 12.18.3.
I installed the previous version again and the labels are normal.
By flags, do you mean custom status icons, labels, or something else?
Sorry, labels.
Can you post a screenshot to show what you mean?
How are they assigned? Is it a wildcard label?
Yes, It is a wildcard label.
Thanks for reporting that, we've put out a new beta which fixes it.
Thanks Jon, it works fine.
