Window size not saving
I am trying to save my DO layout to utilize the right third of my monitor, which always saves the size to half of that. I took a screenshot to illustrate my issue. I'm running 13.6.4 beta on Windows 11 Pro x64 with the latest updates.
How are you saving the layout?
Is the window snapped to the side of the screen (Aero Snap)? Windows won't properly report its position in that situation, as 14 years later Microsoft still haven't added an API to query (or restore) that snapped state. But if you manually resize it to the same place without triggering Aero Snap, it should be saved correctly.
What if I disabled Aero Snap in Windows settings? Will that allow DO to remember the window size?
That would avoid the issue, yes.
You should be able to turn Aero Snap back on again after saving the layout, too.
Thank you very much. That fixed my issue.
