WinKey + E not working
Hello, Winkey + E, not working on W10, I have the following error
DOpusRT: unable to launch Directory Opus from c:\programs Files\GPSoftware\Doirectory Opus\dopus.exe
Is that where Opus is installed?
Does it matter which program is active when you push the key?
If you enable Desktop Double-click (Preferences / Launching Opus / From the Desktop) and then double-click the Windows Desktop background (wallpaper), does that work OK?
same error doing double click on the desktop
The red [Problem with elevation] link in the Preferences dialog is probably indicating what is wrong. Click that for details.
Note that UAC is still on when set to "never notify me", Windows just clicks Yes automatically in any prompts. The other rules for UAC/elevation and process isolation still apply in that state.
