Hi all, on my previous version of Dopus I never had any problems with the Winrar scripts, now when I use the uncrunch and delete script all my files are sent to C:\Windows\System32 instead of the directory I am uncrunching them in, any help would be appreciated.
FWIW there is usually no need to use WinRar directly as Opus integrates it now.
But if you still want to, these threads have the solution:
setting this value to true should help you
Better to fix the buttons to use explicit paths, but yeah you can change that as a quick fix. Some context menu handlers assume the CD will be system32 and it also makes things a bit more secure, but it's up to you.
And, of course, you don't need special buttons which call winrar.exe in the first place most of the time in Opus 10.
