Wrong Command Line After Shift+Del to Remove Line from FAYT
Steps to reproduce:
  1. Press > to open the FAYT bar in command mode.
  2. Assuming there is already an history of commands, press Up multiple times, stop at a random line.
  3. Press Shift+Del, the selected line should be deleted correctly.
Now observe that the next line is selected on the list, but the content on the FAYT bar is from yet another line, and if you use Up and Down some lines now map to the content of other lines.
That has been fixed for the next update.
Thanks for letting us know!
