One Picture is Worth Ten Thousand Words...
That bug should've been fixed in 9.1.2.0; are you running an earlier version?
Or maybe this one (since the paths in the lister and in the error message do not match up):
I am running Version 9.1.3.0.3449.x86.
Maybe you can reproduce it with the attached sample-project (C# - source included)
DOpus Auto-Extract.zip (39.2 KB)
Ah, yes, there is still a problem.
Opus runs the exe with the current dir set to the base of the extracted zip file. If the exe is at the top-level of the zip then it's all good. If the exe is in a subdirectory of the zip then the current dir is incorrect.
I've filed a report to GPSoftware.
Thanks a lot, leo!
