Hello
Can you please tell me where i can find the rename function - dots to spaces which was in Directory Opus 10 ?
Thanks
You could enable the old toolbar and copy the button, it should still be there.
Here is the button
<?xml version="1.0"?>
<button backcol="none" display="both" label_pos="right" textcol="none">
<label>&Dot to Spaces</label>
<tip>Convert '.' characters to spaces.</tip>
<icon1>#rename2</icon1>
<function type="normal">
<instruction>Rename PATTERN="." TO=" " FINDREP</instruction>
<instruction>@nodeselect</instruction>
</function>
</button>
The underscores to spaces function is in a similar place to where it was in the Opus 10 default toolbars:
I don't think Opus 10 ever had a default for dots to spaces.
If you need to turn on your old customized toolbars to grab some of the functions from them, this guide explains how: Your old toolbars are still there after you upgrade.
Hopefully wowbagger's suggestions above do what you want, but if not shout and we can help.
Thanks . Is there a shortcut key for that?
If you edit the menu item (Settings / Customize Toolbars, then right-click the menu item and choose Edit) you can see if it has a hotkey and add or change the hotkey if needed.
Thanks guys.
is it possible to create a single command to change underscore and spaces?
