After updating the version, enter the search word in the Settings Options search box.
The first time you enter the search word, it will be indented and cleared,and the search word will not appear on the screen.
The second time you enter the search word, it will appear normally.
This is a demo video.
Do you mean this only started happening in a particular version?
Which version?
The last few versions should be a long time ago.
I also found this problem, it is no problem to enter the English letters alone.
I guess it is related to the IME, and it is estimated that it was introduced by fixing the IME-related bug last time.
Which Opus version are you seeing this in?
After many iterations of installation testing I can now confirm that the bug appears in version 13.3.2
On February 27, I mentioned a bug about the Chinese input method in the post Some small suggestions and Bug feedback
This was introduced when fixing the bug in 13.3.1beta. Hopefully it will be fixed in the next version.
