Add A Column Header "Label" in Music Section
I have Used dBpoweramp CD Ripper for Rip My Audio CD. I Add A Metadata Called "Label" Before I Rip my CD. In this Screen Shot I Add the metadata "Soundtek" in the "Label" Column
I Want to Display This Metadata in my Directory opus File Display in Details View. But There is no Header Like "Label" Which Represent the Metadata "Soundtek" . So Please Add A Column Header "Label" Under the Music Section.
NB: All of my music file extension is FLAC
Hi to all, Please someone give a reply
Please be patient.
Hi Dear Leo How Long I have to be patient?
I guess if there's been no reply it means it's not possible.
not possible!! I am really can't believe that the most power full software directory opus can't display data from audio file
Or nobody felt like spoon-feeding a petulant toddler
You may be able to write a script which uses exiftool to extract the metadata ready to display in an Opus column. It says it can deal with .flac files but it will depend too on dbpoweramp folowing the standards.
Does the label tag show in Explorer. If so, you may be able to do it with scripting without Exiftool.
A lot of work for a column you could just stop using and replace with the description or tags columns.
