Always in keyboard mode issue
Hello. I have an issues with arrows keys up/down in PowerMode. it doesn't work... (DO .0.44 and prev)
I can't reproduce this so far.
Does it only affect Power mode, or others as well?
Does Customize / Keys show the cursor keys have been overridden?
yes, all modes
nope, there was only alt+↑/alt+↓, but turning them off does nothing.
also ←/→ for Go command, but disabling makes no sense.
Seems like the cursor key is being intercepted by something. Are you using AHK or anything similar that might be doing that (maybe only when certain windows/titles are active)?
not used
may be it's a CarambaSwitcher (have no other ideas, it controls the two Shift keys to disable autocorrect and one Shift to keyboard layout change)
may be it's a Ctrl lock as here
