Best way to transfer v9 config customizations to v10
Hi Opus,
I have made customisations to v9 in the following areas :
  • new menu items
  • new top-level menu-item (undo)
  • hotkeys
  • context menus
  • preferences
What is the easiest way to xfer those to v10,
especially given those changed significantly in v10.
Wrt the menus =>
e.g. is it possible to run v9 & v10 at the same time, side by side, and
copy entries from a v9 menu to a v10 menu ?
Cheers,
Brian
Just install 10 over 9 (do NOT uninstall as that wipes your config), and please see: Your old toolbars are still there after you upgrade
