Blank / Spacer Column
An extremely basic script that lets you add an empty column with no header. Can be used to easily add spacing from the side of the window or anywhere.
Example:
Usage:
Installation
  • Download BlankSpacerColumn.js.txt (617 Bytes)
  • Open Preferences / Toolbars / Scripts to display the list of scripts.
  • Drag the downloaded BlankSpacerColumn.js.txt to the list.
