Can't change drag and drop options - no file type settings visible
hi all.
was away for a while but an issue from back then made me return and it was license time.
the 'issue' i'm having is that i can find no way to edit the default drag and drop settings via 'File Types' as detailed here.
i see no option for Settings > File Types and i have been right through the preferences
20220102081720604
20220102081736885
thanks.
FileType editing is not in Opus Light, only Pro.
ah, thank you. i didn't see that documented anywhere.
guess i'll be saving up for pro.
cheers for the info.
