Command field in floating toolbar
Hi,
I've added the command field button to a floating toolbar. Now when i insert a command to execute, nothing happens. When i add the command field to a toolbar part of a lister, all works fine.
Is this normal behaviour because the lister loses focus when the command field is selected on the floating toolbar.
Thanks,
John.
9.1.0.6 | XP Pro SP3.
The command field adds a text entry field to a Toolbar that lets you enter a command string that is executed immediately in the current lister.
So, I think the command field doesn't work in Floating Toolbars.
And Leo wrote this ([url]A few issues with floating tool bars]):
