Context menu not visible (DisplayFusion 9.7 Beta 7)
Whenever I right-click in Opus all I can see is the drop shadow of the context menu but I can't see the actual menu. I can still click the menu and it will respond. I have tried uninstalling and reinstalling but it didn't help. It also does the same thing on the tray icon as well.
I made a short video that shows the problem: https://youtu.be/Yq5AVEggjX4
This has come up a couple of times (although not for a long while); it seemed to be a graphics driver bug. Try upgrading to the most recent driver for your video card (or, if you have upgraded recently, try rolling back to the previous version).
Same issue with Windows 10 64bit Pro (up to date), AMD Adrenalin 2020 20.1.12-Jan15 driver and DOpus 12.20
The problem seems to be related to the DisplayFusion (latest beta?): https://www.displayfusion.com/Discussions/View/97-beta-7-problems/?ID=0b2e052b-31b7-4f60-a5a7-e018ae857740
Temp fix: Open Displayfusion Settings > Compatibility (from left panel) > Add dopus.exe via 'Select Application' and select 'Disable Application Hooks (this application only)' then click 'OK'.
You beat me to it, just discovered DF is the culprit.
Thanks for the fix.
BOOM! Thank you! Just had this problem kick off this morning.
That fixed the issue thank you so much. I really appreciate it.
