Huh??? Didn't you read the very last post from 25 Oct 2005? GPSoft did indeed add this support internally with the 8.2 release. Everything that used to require the 4 separate commands in the quote you mentioned can now be done with the one new command mentioned in my last post. If it wasn't clear from the previous posts, you can change the {d} to {s} if you want the new folder created in the 'current/source' folder instea dof in a destination folder.
[quote="mrwul"]Actually I would have to make a study of it again, how I got it working
, so best is that this is one of the default things of DO,
right?[/quote]
Check out the Settings->Import and Export... feature. There should be very little reason to have to ever go back and figure something out again if you export your settings periodically. The feature saves all customizations to a single (.DPS) file which you can always re-import to get all of your settings back. I suggest keeping several copies of exported settings around... one you consider to be a 'known' stable and properly working configuration, and then 'incremental' settings as you experiment with changing your configuration to do new things.[/quote]
Hi,
Oops!
eh...
Well, frankly, no, I was not subscribed to this thread anymore. Sorry.
However, as I am using this feature sooo many times and am very happy with it (ever been reorganizing many hundreds of photos and other stuff?)
and was wrongly assuming that it would not have been included i thought i would re-start this thread again.
I have not yet used the new feature of 8.2: still using the below .cmd file.
Have shortly glanced at the 'overview of new features' but cud not trace this new feature being mentioned.
As said, I am still using the .cmd-file which was given earlier in this thread.
rem BEGIN BATCH FILE
@echo off
dopusrt /cmd CreateFolder %1
set DST=%1
:loop
shift
if {%1}=={} exit
dopusrt /cmd Copy %1 TO %DST%
goto:loop
rem END BATCH FIL
Have to tell, I am an 'simple end-user' only. Most likely I am using only a fraction of DO's power and features.
Because me being just an end-user, pls accept that I am not familiar with all these 'expert'-internal command-things.
The above works fine and frankly I have to go way back in this thread to find out hรณw I got it working...
Same as that one way or the other I have managed to get three buttons (all being the same) for an external program in my toolbar.
(\flashrename.exe). Spent already quite some time to figure out how I can get rid of it. Actually, I gave up and will leave the buttons there
(one of them even does not work, it produces an error).
Guess if I were to re-install DO, then they will be gone.
(this is one of the reasons for me asking whether the create folder feature was part of 8.2 - being afraid that after a fresh install I had
to go all over the create folder.cmd-file-stuff again to get it working etc. ahum)
See, this is just one of those things, where an expert wud say, look there and there and do that.
Same as that I'd like to have 'create folder' under the RMB.
Same as I wud like to have the box-size (above .cmd-file) say a dozen characters wider,so I cud see a bit more of the path.
But then again, those are really minor things.
As for .dps - thank you for yr advice. Have very recently started to export settings.
Thank you again.
