Detect active explorer replacement (from extern)
During usage of the Jumptofolder tool some questions came up.
To support NotNull I will ask two questions (each in a separate thread):
Is there an easy and reliable way to detect (from extern) if explorer replacement is activated?
For current Windows versions, you can find out by checking the default value of
HKEY_CLASSES_ROOT\Folder\shell
It will be set to openindopus if Explorer Replacement is on.
(This could change in the future if Windows changes and requires we do something different, but I don't think it has changed since Vista or maybe Windows 7.)
