Device unplugged annoying popup
Everytime I start dopus there's popup saying "device is removed etc".
Is it possible to add a feature that dopus would automatically detect if device is not plugged to pc anymore, and it would not show that specific directory nor the annoying popup anymore?
The settings under Preferences / Folders / Auto-Loading let you tell Opus to not automatically read folders from certain drive types when opening new windows (until you click on something to tell it to go ahead and read the folder).
Alternatively, if you do not want Opus to remember the folders which were open the last time it was used, and would prefer it to always open specified folders that never change and are always there (e.g. C:\ or Desktop), the short Startup Folders guide explains how to do that.
Which one do you select to make this happen, Prevent loading or Load on tab activation?
Prevent Loading is probably the one you want, from what I can see in the screenshot.
I'll try that one out, thanks!
