I've built a very simple dialog in the dialog editor; it only contains 2 buttons.
The dialog is resizable. Both buttons are set to update Y and WS. However, when I resize the dialog, this happens:
The Ok button is updated, the Cancel button is ignored.
The issue is related to the tab order: In the above example, OK is in position 1. If I change the order, the Ok button remains unchanged instead of Cancel.
Removing the Shared Width setting still results in only one of the buttons' y-position being updated.
This is the dialog:
<resource name="dlgTest" type="dialog">
<dialog height="40" lang="english" resize="yes" width="64">
<control close="0" default="yes" height="14" name="btnOk" resize="yws" title="Ok" type="button" width="25" x="5" y="26" />
<control close="0" height="14" name="btnCancel" resize="yws" title="Cancel" type="button" width="25" x="33" y="26" />
</dialog>
</resource>
Is there any other setting I need to change or is this a bug? I've seen similar problems were recently fixed...
Thanks!
