i don't know what the deal is, but sometimes when i remote into the machine, DO won't launch, sometimes when i kill the process it will then work, but thats only about 25% of the time. i usually just can't get it working at all. i tried it on a couple machines to test and all with the same result. not sure whats causing this.
well, i have it fully replace explorer, so i generally just click start, computer or one of my other shortcuts like downloads, pictures and so on. when that doesn't work i try to launch the actually DO program.
ok, it doesn't happen all the time, but i have now tested on 2 different windows 7 x32 machines after fresh format, and it happens on both. and it's not that it just won't launch, there is just a point where it stops responding entirely, now, i don't get the Not Responding message, as it looks like it isn't frozen and working fine except that it doesn't respond to anything. also, if i right click on the icon and try to exit that way, i get a system sound like it is waiting for some confirmation, only there is nothing to confirm, if i kill the 2 exe's in process viewer it will close obviously, but i try to launch again and nothing, won't work until i reboot.
If they're really vanilla machines (other than Opus being installed) then it could be something you've configured the remote desktop client to do, e.g. mount a local drive, printer or USB device on the remote machine.
Are they really fresh machines with nothing at all installed except Windows and Opus, though? No anti-virus? No video card drivers? No video codecs? Nothing at all in the Uninstall control panel? etc.?
RDPClip is often the cause of issues, I've found. (Not just with Opus.) Although I've not heard of it causing this problem before and I haven't had issues with RDPClip lately. (FWIW, the only combination I use these days is Win7->Win7, which might be a factor.)
If you have any clipboard monitor/history tools I guess they may be related. Or maybe if you have a huge amount of data (or an unusual type of data) in the clipboard when you connect, I suppose.
[quote="leo"]RDPClip is often the cause of issues, I've found. (Not just with Opus.) Although I've not heard of it causing this problem before and I haven't had issues with RDPClip lately. (FWIW, the only combination I use these days is Win7->Win7, which might be a factor.)
If you have any clipboard monitor/history tools I guess they may be related. Or maybe if you have a huge amount of data (or an unusual type of data) in the clipboard when you connect, I suppose.[/quote]
it is possible it's a clipboard issue, who knows, i'm usually connection from my macbook pro to a windows desktop/server, i guess that could also be the issue, but it sux LOL
i am using the latest that comes with office 2011. i am also running windows on it through bootcamp and parallels, i'm going to keep my eye on it now that i have a sort of work around, enxt time it happens i'm going to check my clipboard
well, it still happens, i use the latest RDP client on OS X connecting to a windows 7 machine, i've installed DO on another windows 7 machine, and it happens there as well. only problem is i cannot figure what is causing it, seems random, but once i kill the rdpclip.exe then it works, in fact, it performs all standing actions
Try disabling remote sound routing in the OS X RDP client. That suggestion worked for a couple of people in one of the (many) threads I found in a Google search for "OS X" rdpclip (where the symptom for most people was rdpclip.exe using 100% CPU on the machines they connected to; is that happening for you it you open task manager?).
TBH, it seems like an issue with the OS X RDP client and/or rdpclip.exe rather than Opus.
