Disable "Folders on top" by sorting. Is it possible?
Hi guys.
i have a quick short question, i hope there is a quick short answer too.
Is there an option that activate "treat folders like files" by sorting.
I mean a way to disable "Folders on top" by sorting. Is it possible?
Thanks!
PS: why i need this?
When i work with archives and have many of them in a folder
By unpacking with the option one-folder-for-each-archive
i get a lot of rows displayed, but what if i am not sure if i selected all rars and zips.
The simplest solution in my mind is optical comparison by alphabetical sorting.
(but folders should be treated like files and be not on top)
Yes, using Folder Formats.
When editing Folder Options or a folder format, the Display tab has a Mixing drop-down which lets you choose between folders on top, files on top, or both mixed together.
