Is there a way to randomize files/folders when Manual Sorting is turned on? I'm not looking to randomly select files to open. I'd just like a randomness of my files/folders to be all mixed up for viewing. I figure with the new Manual Sort, this could be possible (sorry, I can't write scripts). Would be great if it was a button that toggled Manual Sorting and the randomness at the same time.
You would need a script to randomise the sort. (A script could also do it via a column with random sort-as values, although using Manual Sort is possibly cleaner. A script is required in either case.
I have a more recent version of the CustomGrouping column set (Columns: CustomGrouping (group by SizeRange/FileTypeGroup..)). It has an additional random column, which when sorted, gives you a random list of files and folders. If you think this would be of help to you, I can upload that tomorrow.
I guess that would work. I can't be picky if I don't know how to program now can I
I would rather use the builtin new Manual Sorting feature because it can be saved, no extra column is added, items can be moved around if needed and the icon shows if it's manual or auto or saved or unsaved.
