I have a hard drive 'H' which contains image files that I store for safekeeping. I have a lot of DVD's with image files. WhatI am trying to figure out is how to check if the files on the DVD exist in th 'H' drive, and I need Opus to display only the files on the DVD that do not exist in 'H'
Could you steer me in the right direction. I am a new user with Opus and it is a tad confusing at times.
Possibly Tools -> Find Duplicate Files.
I'm not familiar with the details of that function, but it looks like the place to start.
This code will select non matching files..
Select ALL
Select SOURCETODEST DESELECTNOMATCH
Select DESTTOSOURCE DESELECTNOMATCH
Select INVERT
Drop off the Select INVERT if you want to select matching.
Regards, AB
