This evaluator expression works as expected, correctly setting the button label to BC5 if the executable exists.
@label:=return (Exists("/programfiles/Beyond Compare 5/BCompare.exe")) ? "BC5" : "BC4";
An attempt to do the same thing using evaluator variables returns an error.
bc4 = Exists("/programfiles/Beyond Compare 4/BCompare.exe");
bc5 = Exists("/programfiles/Beyond Compare 5/BCompare.exe");
@label:=return (bc5) ? "BC5" : "BC4";
The error message is:
Conditional compilation is turned off (0x800a0406)
Is my syntax wrong?
