Firefox, windowblinds file save dialog wrong graphics, missing right click menu
Occasionally when downloading files with FF the save as dialog of FF doesn't work properly. I'm not sure if it's DO, FF or windowblinds that I also use.
Additionally when trying to create for example a new folder in the save as dialog, the menu is empty (or missing the text labels and contain only small arrows where the menu has submenus.
I have DO set to replace explorer if that matters.
windowblinds
And Opus doesn't replace the File Open/Save dialogs:
It's just little weird as I have excluded (since many years) firefox from being skinned and this whole problem started to appear only in the last few months.
No updates to anything else than Firefox and DO (excluding Windows and AMD driver updates) windowblinds haven't been updated in years either.
Well most of my troubles with DO have been user errors so maybe it's the same with this. I just hoped someone else had seen this same bug and had a solution.
Definitely not related to Opus. Opus doesn’t modify the File Open dialogs or visual styles outside of its own process, so it would not affect them in Firefox.
