Hi all,
as I could see here: NTFS Junctions, Circular References, Folder Size Calculation
Dopus can stop at junctions in a flat view. Fine.
But what if I want exactly the opposite?
Can Dopus also follow junctions in a flat view?
Thx.
Hi all,
Thx.
It doesn't stop at junctions; it only stops when it detects a junction which points back on itself and would cause an infinite loop.
(You can see from a screenshot just after that one in the same thread.)
ok, thx
