Hello,
Previous versions did not have freeze colums to here, so when I opened dopus I always got to see the full directory name, but with this new feature it does not work everything is compressed i have to everytime adjust it manually it does not make a difference if I use the feature or not.
I have a 57 inch samsung monitor, but that shoud not make a difference, when I adjust it to the right size (the colums) it stays in place until I close dopus and reopen a lister
Thank you, I got that wrong but even with the right procedure it does not work, I widen the colum save it as described it does not remain there when I return to that lister
Open Folder > Folder Format (or Folder Options, if using old menus) and see what the column widths and modes are set to there. Some modes may override manual resizing.
