Help menu links after switching language
it seems that by removing the option, our links to the german forum are no longer available!
installation 13.2 (german)
links/redirections in help and "via directory opus"
to the german forum exist.
switch to english
all links/redirects point correctly to gp
switch to german (links now point to gp)
here the menu bar/operation bar often remains in english
so that you have to choose another language (not english) and then switch back to german to change it.
resetting the bar to the factory setting does not change these links.
only a complete de-/install will show this correctly again.
What does this have to do with the Check Language button, which just generates a text file?
weren't the entries for the german forum set here in the missing menu item?
the redirection to our forum was only for us!
by changing the languages, this is probably no longer there because he no longer knows the links for checking!
Which links do you mean? Specifically?
grafik
4 of them are linked incorrectly and one is now duplicated?
same under
grafik
If you edit those buttons what links are they going to?
editing not possible, opens the website directly
normally this is published
before you see this briefly
after switching
https://www.gpsoft.com.au/
There's nothing special about those buttons. You can definitely open them in the button editor, the same as any other.
https://www.gpsoft.com.au/DScripts/redirect.asp?page=home
The &lang=deutsch part is added automatically when you're running in German, and is what causes the redirect to the German site. If you're running Opus in English then it's not added.
yes, that is correct.
only after switching to german this remains with the english links
this was used several times in the betas for testing.
problem has only been present since 13.1.
only noticed now because users had asked why the links
no longer go to our pages.
The links in the buttons don't change when you switch language. Changing languages updates button labels but it doesn't modify functions.
When you're running in German, &lang=deutsch is added automatically to the URL when Opus opens the website. When you're running in English it's not added. That's all that's happening here.
Video shows
german = link ok
switch to english, your pages
switch to german, no longer our pages but yours
I've split this into its own thread, since it had nothing to do with the one it was in.
FWIW, I cannot reproduce what you're seeing, at least with the default toolbars.
I can switch back and forth between English and German multiple times, and this always goes to the appropriate page for the current language:
It remains an open problem for other users!
It's a game of chance whether it works.
On various test systems with Windows 10/11 the result is always different.
Info: The video was with Windows 11
Something gets mixed up when switching the language.
Either the links are then incorrect or the toolbars remain in English.
Resetting the toolbars does not work.
The issue is closed for me as it works on my system with Windows 10.
I can confirm the problem mentioned by Nobmen. Last week all my links went to the GP pages. I then did various experiments. Later, after switching between German and English a few times, all links were correct again.
Are you sure Opus wasn't running in English or another language (maybe still with German toolbars, if the translation option wasn't used when switching languages)?
I've tried it several times and it always goes to the link for the current program (not toolbar) language. I've also looked at the code and can't see how it would ever do differently, at least from simply switching languages.
could be due to the language of the operating system?
test were:
the installed german windows 10/11 with english login account extended.
added the possible addition to switch to english language for german windows.
when the installed english dopus version switches to german and back
the problem with the wrong toolbars also occurs from time to time!
was noticed for the first time with beta 0.35.
this also fits
