I've set DOpus to allow manual sorting and then saved this as the default file format. So I can sort files manually, those sort orders get saved, and those orders still persist once folders are closed and appear when folders are reopened. So far so good.
My question is: My files themselves can be backed up just fine using cloud services, USBs, etc., but what is the best way to back up my within-DOpus saved manual sort orders and export them to an external medium?
Like: does the USB license solve this problem? Is a disk image with files & DOpus data together precluded because of licensing issues? Or is there really not a practical solution involving saving DOpus data & files themselves separately because sort orders and files continually evolve and so wouldn't map properly to each other after diverging?
