Hi !
Was searching google to no avail to understand what some icons mean in DO, like this one :
Hmm - I see no way to edit my message : so my question is
A) Is there a reference ?
In this particular example I would expect to see the sandbox icon - is it an indication of a mistake ?
DO 10 - win7 sp1 pro
Do you get the same icon overlay for the same folder in Explorer?
nope - actually in explorer I don't get an icon overlay but an icon specified in the desktop.ini I guess :
Desktop.ini:
[.ShellClassInfo]
IconFile=C:\Program Files\Sandboxie\SbieCtrl.exe
IconIndex=9
IconResource=C:\Program Files\Sandboxie\SbieCtrl.exe,9
InfoTip=This folder is a work area created by the program Sandboxie.
Anyway - is there a reference for the icons DO is using ?
I see this same blue arrow on my C:\Users\USER folder
And thanks for the very quick reply
EDIT (duh) : I restarted DO and it displays the windoz help icon on both the sanbox folder && my profile folder
So I guess something fishy goes on ...
Still I'd like to know if there is a reference - explaining the DO icons
BTW why can't I edit my posts ? - I am a bit of maniac about typos etc
Try clearing the shell icon cache and rebooting:
Clear Icon Cache
Regarding post editing, see the FAQs.
Thanks !
No more strange icons are displayed - but no icon at all is displayed when folder not selected :
but :
I guess an icon weirdness again - I have Opus calculate folder sizes - dunno if related
And will read the FAQ next time :promise:
Thanks
Thank you very much
So should I be seeing it here ? :
Is there a way to "refresh" the icons in opus ?
I still do not see icons when some folders are unselected - in C: for instance I have those :
I see the sandbox icon when I highlight the sandbox folder and a normal folder icon when I highlight the RB or System volume Information
Thanks
Could you use Settings -> Backup & Restore to create a backup of your configuration, then send me a copy via a private message?
