Is there a way to have Opus display two different images side by side?
When double-clicking an image Opus will show this image.
There is a 2nd image that I would like to compare it with, both in original size.
They are scanned images but with slightly settings and I would like to see which one is the best.
I tried launching Opus a 2nd time but when double-clicking the 2nd image, it will replace the 1st one, instead of showing the 2nd image in a different viewer.
Any suggestions ?
Thanks.
Thanks.
Images are associated to D8Viewer
Multiview is enabled in settings
Recycle? No idea where to look.
Selected 2 images, hit enter, 1 image is displayed.
I can go back and forth from 1 to the other, but not side by side.
Sorry.
You have to double click on each image. Or select and enter per each image.
I use Compare and it works great. Compare Images Close Button Help
Super..
Thank you so much for responding here!
That works perfectly.
Thanks again.
